TwinTurbo.NET: Nissan 300ZX forum - Re: Re: stumble/hesitation problem
Potacka
on May 18, 2015 at 9:52 PM
posted by FrozTTy
on May 18, 2015 at 09:41 PM
Pugs are ngk pfr6g-11
Coolant temp sensor was replaced 8,000 miles ago. I tested it cold and readings were ok, I also removed it to visually inspect seemed fine.
I will try swapping the fpr with a spare that I have.
Thanks
Potacka
17:34:13 05/18/15
CarolinaZ_TT
17:57:22 05/18/15
Potacka
19:02:50 05/18/15
Connector corrosion someplace, or possible wire
ttz'in (norcal)
19:21:23 05/18/15
Re: Connector corrosion someplace, or possible wire
Potacka
20:01:56 05/18/15
Duke51
21:12:16 05/18/15
Potacka
21:46:26 05/18/15
Re: Re: Re: stumble/hesitation problem
Duke51
01:40:24 05/19/15
FrozTTy
21:41:04 05/18/15
Re: Re: stumble/hesitation problem -
Potacka
21:52:37 05/18/15
Potacka
21:53:14 05/18/15
CarolinaZ_TT
09:16:57 05/19/15
Re: Re: Re: Re: stumble/hesitation problem
Potacka
09:36:44 05/19/15
Re: Re: Re: Re: Re: stumble/hesitation problem
CarolinaZ_TT
10:02:05 05/20/15
You mentioned you changed the CAS and it was 90% better.
nonstopna
13:09:01 05/20/15
fixed
Potacka
18:24:11 05/20/15
I would install new oem fuel filter also (n/m)
FrozTTy
20:23:53 05/20/15
